Mongo Wizards - threshold fields need to be bigger
Post by Box293 »
I was playing around with the two Mongo Wizards in XI 2014 and noticed that the threshold fields are too small, they need to be wider.
You can see from the screenshots that they have values larger than what can fit in the field.
