[Mysql monitoring wizard] difference between low and high?
skywalker
Post by skywalker »
I want to monitor the usage of indexes on MySQL.
So, I used “MySQL Server Monitoring Wizard”.
I want to know the meaning of “high” and “low”on thresholds.
What is the difference between “ low %and high %” in warning thresholds?
I have configured MySQL monitoring wizards.
After configuration, the index usage show wrong results.
The usage of index is 2.4 percent. But nagios displayed critical status.
Used command is check_xi_mysql_health.
ARG1 is “--hostname=172.16.0.23 --port=3306 --username=root --password="root" --database=rpms --mode index-usage --warning 90: --critical 80:”
Re: [Mysql monitoring wizard] difference between low and hi
Post by slansing »
Having a ":" after your threshold value with nothing to range between is essentially, in this case, saying:
Change to a warning state if less than 90.
Change to a critical state if less than 80.
I think you need to fix up the thresholds you set a bit if you are going to use the more advanced options, you should read about them here:
https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT
