Hi All,
Since my upgrade to 2014R1.1 it seems I'm getting the following under my /usr/local/nagios/var/nagios.log
[1402332008] Warning: Check of host 'xxxx' could not be rescheduled properly. Scheduling check for Mon Jun 9 12:41:08 2014
Wondering if there would be a fix for this as it's pretty constant and appearing for every host under the log file and this was not appearing before the upgrade.
Sincerely,
Michael
NagiosXI 2014R1.1 LOG File could not be rescheduled properly
Re: NagiosXI 2014R1.1 LOG File could not be rescheduled prop
Do you have debugging turned on?
Please run that and post the output.
grep "debug" /usr/local/nagios/etc/nagios.cfgFormer Nagios employee
Hi tmcdonald,
Below is my output:
I've also recreated the debug file as it seemed to have been missing.
Below is my output:
[root@NagiosXI ~]# grep "debug" /usr/local/nagios/etc/nagios.cfg
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
max_debug_file_size=1000000
[root@NagiosXI ~]#
[root@NagiosXI nagios]# touch /usr/local/nagios/var/nagios.debug ; chown nagios:nagios nagios.debug;
[root@NagiosXI nagios]# ll /usr/local/nagios/var
total 187468
drwxrwxr-x. 2 nagios nagios 4096 Jun 9 23:59 archives
-rw-r--r-- 1 nagios nagios 0 Jun 10 12:14 nagios.debug
-rw-r--r-- 1 nagios nagios 6 Jun 5 03:15 nagios.lock
-rw-r--r-- 1 nagios nagios 78323355 Jun 10 12:31 nagios.log
-rw-r--r-- 1 nagios nagios 5 Jun 4 18:41 ndo2db.lock
-rw-r--r-- 1 nagios nagios 0 Jun 5 03:14 ndomod.tmp
srwxr-xr-x 1 nagios nagios 0 Jun 4 18:41 ndo.sock
-rw-r--r--. 1 nagios nagios 44251 Jun 10 10:25 npcd.log
-rw-r--r--. 1 nagios nagios 48300472 Apr 11 13:01 objects.cache
-rw------- 1 nagios nagios 65259532 Jun 10 12:15 retention.dat
drwxrwsr-x. 2 nagios nagcmd 4096 Jun 5 03:16 rw
drwxr-xr-x. 5 nagios nagios 4096 Mar 21 14:48 spool
drwxr-xr-x. 2 nagios nagios 4096 Jun 10 12:31 stats
@mlopez - Could you post your current /usr/local/nagios/etc/nagios.cfg as this may be helpful for both this post as well as your other post
http://support.nagios.com/forum/viewtop ... =6&t=27513
Thanks!
Thanks!
Hi Scott,
Below is my /usr/local/nagios/etc/nagios.cfg
[root@NagiosXI etc]# cat /usr/local/nagios/etc/nagios.cfg
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
#service_perfdata_file=/usr/local/nagios/var/service-perfdata
service_perfdata_file=/var/nagiosramdisk/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
#host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file=/var/nagiosramdisk/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/var/nagiosramdisk/spool/checkresults
#check_result_path=/usr/local/nagios/var/spool/checkresults
check_service_freshness=1
#command_check_interval=-1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_level=0
debug_verbosity=1
#enable_embedded_perl=1
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
#external_command_buffer_slots=4096
high_host_flap_threshold=20.0
host_check_timeout=30
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_external_commands=0
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=0
log_rotation_method=d
log_service_retries=1
low_host_flap_threshold=5.0
max_check_result_reaper_time=30
max_concurrent_checks=0
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/var/nagiosramdisk/objects.cache
#object_cache_file=/usr/local/nagios/var/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
#p1_file=/usr/local/nagios/bin/p1.pl
perfdata_timeout=5
precached_object_file=/usr/local/nagios/var/objects.precache
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=60
service_interleave_factor=s
#sleep_time=0.25
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/var/nagiosramdisk/status.dat
#status_file=/usr/local/nagios/var/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/var/nagiosramdisk/tmp
#temp_path=/tmp
##use_embedded_perl_implicitly=1
use_regexp_matching=0
use_retained_program_state=1
use_syslog=1
use_true_regexp_matching=0
sreinhardt
- -fno-stack-protector
Could you turn debug_level=0 to debug_level=16 in nagios.cfg, restart the daemon, and send us the debug log in an hour or so? Probably best to PM that over.
