Service template errors while running XI import procedure
rickwilson7425
Post by rickwilson7425 »
I am having a problem with several service definitions when trying to import the templates file into XI.
I believe it has to do with the illegal characters in the "action_url" string, particularly the leading ../../
I am not sure what this is trying to do or how to direct the service in XI. Any help would be appreciated.
Here is the definition:
# Generic service definition template 5 minute interval
name generic-service-5
action_url ../../pnp4nagios/graph?host=$HOSTNAME$&srv=$SERVICEDESC$
active_checks_enabled 1
check_freshness 0
check_interval 5
check_period 24x7
event_handler_enabled 1
flap_detection_enabled 1
is_volatile 0
max_check_attempts 3
notes $_SERVICEHTMLOPEN$ Service Priority: $_SERVICEDOC_PRIORITY$ $_SERVICEHTMLBREAK$ Tech Contact: $_SERVICEDOC_TECHCONTACT$ $_SERVICEHTMLCLOSE$
notes_url http://confluence.jeppesen.com/display/TSS/Home
notification_interval 60
notification_options w,u,c,r
notification_period 24x7
notifications_enabled 1
obsess_over_service 1
passive_checks_enabled 1
process_perf_data 1
register 0
retain_status_information 1
retry_interval 2
_DOC_PRIORITY 5
_DOC_TECHCONTACT Not Identified
_HTMLBREAK <br>
_HTMLCLOSE </p>
_HTMLOPEN <p align=left>
Re: Service template errors while running XI import procedur
Could you just give it an absolute URL as opposed to the relative? Although that shouldn't really matter as those characters are not illegal. What's the actual problem or error you are experiencing?
rickwilson7425
I am getting this error when trying to verify my config in CCM:
Error: Template 'generic-service-5' specified in service definition could not be not found (config file '/usr/local/nagios/etc/services/DENALTSMP01P.cfg', starting on line 62)
Nagios Core 4.0.6
Last Modified: 04-29-2014
License: GPL
Reading configuration data...
Read main config file okay...
When I go into CCM and open the Service Templates tool I get a message that says there are illegal characters in the definition for the above referenced "generic-service-5". When I remove the leading "../../" in the action-url I don't get that message any more.
I assumed that those illegal characters were the cause of the definition not being written out to the configuration files and that is why I am getting the above error message.
abrist
Red Shirt
Post by abrist »
rickwilson7425 wrote: I assumed that those illegal characters were the cause of the definition not being written out to the configuration files and that is why I am getting the above error message.
You assumed correctly. XI has graphs on the details page under a different tab. Do you need the action url?
rickwilson7425
I think so. It is used in a whole bunch of server monitors and in 2 other service definitions that I have found so far. The only difference in those is the check times, one is 5 minutes, one is 10 minutes and the other one is 15 minutes.
abrist
Red Shirt
Post by abrist »
You may want to use a full path for the action url. In 2014, the path to the old perfgraphs is:
/nagiosxi/perfgraphs/?&host=<hostname>&service=<service description>&source=1&view=1&start=&end=&startdate=&enddate=&mode=2
