I'm getting the messages below when applying configuration after upgrading to 2014R1.1.
Nagios Core 4.0.6
Last Modified: 04-29-2014
License: GPL
Reading configuration data...
Warning: use_embedded_perl_implicitly is deprecated and will be removed.
Warning: sleep_time is deprecated and will be removed.
Warning: p1_file is deprecated and will be removed.
Warning: external_command_buffer_slots is deprecated and will be removed. All commands are always processed upon arrival
Warning: enable_embedded_perl is deprecated and will be removed.
Warning: command_check_interval is deprecated and will be removed. Commands are always handled on arrival
Read main config file okay...
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/http-linux.cfg', starting on line 14)
Please note that I also received the message below after the upgrade.
Thanks in advance.
Error when Applying Configuration
Re: Error when Applying Configuration
It looks like your http-linux service has no service description. If this is the case you may have several services with this same issue.tgfde wrote:Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/http-linux.cfg', starting on line 14)
Please advise on how I could fix this issue. I was not receiving this error prior to my upgrade.
Thanks in advance.
Thanks in advance.
You need to edit the service: "http-linux".
Check to make sure it has a service description and that it is applied to at least 1 host or hostgroup.
Thank you!
