Potential Customer Watchguard Wizard
sms380
Post by sms380 »
I'm trying to use the Watchguard Wizard to set up monitoring of our Watchguard XTM 525 firewall. So far I'm using a trial version of Nagios XL.
Currently I have setup the SNMP rule and the Setup->SNMP section in the firewall. When I run the Nagios Watchguard wizard it tells me "No ports were detected on the switch." No matter what I do I can not seem to get this working.
Please Advise I was hoping these wizards were going to make the setup much easier. So far I'm a little disappointed.
Thx SMS380
Re: Potential Customer Watchguard Wizard
Post by slansing »
Do you have the correct community string and SNMP version selected?:
http://assets.nagios.com/downloads/nagi ... _Usage.pdf
You could also try running the Switch/Router wizard against it.
