Nagios install/Ubuntu
I finished the install and no errors after I checked the config file. Now I dont see the Objects folder inwhich to configure the windows.cfg file so i can instlall my windows servers. I also am getting an error related to not authorized. I cant find these files to edit CGI.CFG also.
Re: Nagios install/Ubuntu
We don't support Ubuntu.
Though if you provided more information I might be able to give you a tip or two, like the install should be under /usr/local with two main folders nagios and nagiosxi.
If you get this working we would probably like to add any notes you have on the experience to an unofficial documentation section.
Thank you!
Thank you!
