2012R2.7 fails to uipgrade to 2014R1.1
KiwiBloke
Post by KiwiBloke »
I have tried to upgrade one of our NagiosXI servers (2012R2.7) to the latest version using the normal upgrade process.
However, it seems to work, but fails right at the end. I managed to grab the following off the console.
Any ideas? (the reboot at the end was me)
  make install
     - This installs the main program, CGIs, and HTML files
  make install-init
     - This installs the init script in /etc/rc.d/init.d
  make install-commandmode
     - This installs and configures permissions on the
       directory for holding the external command file
  make install-config
     - This installs *SAMPLE* config files in /usr/local/nagios/etc
       You'll have to modify these sample files before you can
       use Nagios.  Read the HTML documentation for more info
       on doing this.  Pay particular attention to the docs on
       object configuration files, as they determine what/how
       things get monitored!
  make install-webconf
     - This installs the Apache config file for the Nagios
       web interface
  make install-exfoliation
     - This installs the Exfoliation theme for the Nagios
       web interface
  make install-classicui
     - This installs the classic theme for the Nagios
       web interface
*** Support Notes *******************************************
If you have questions about configuring or running Nagios,
please make sure that you:
     - Look at the sample config files
     - Read the documentation on the Nagios Library at:
           http://library.nagios.com
before you post a question to one of the mailing lists.
Also make sure to include pertinent information that could
help others help you.  This might include:
     - What version of Nagios you are using
     - What version of the plugins you are using
     - Relevant snippets from your config files
     - Relevant error messages from the Nagios log file
For more information on obtaining support for Nagios, visit:
       http://support.nagios.com
Enjoy.
cd ./base && make install
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6                                             /base'
make install-basic
make[2]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6                                             /base'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/bin
/usr/bin/install -c -m 774 -o nagios -g nagios nagios /usr/local/nagios/bin
/usr/bin/install -c -m 774 -o nagios -g nagios nagiostats /usr/local/nagios/bin
make[2]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6/                                             base'
make strip-post-install
/usr/bin/strip /usr/local/nagios/bin/nagios
/usr/bin/strip /usr/local/nagios/bin/nagiostats
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6/                                             base'
cd ./cgi && make install
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6                                             /cgi'
Makefile:169: warning: overriding commands for target `tac-xml.cgi'
Makefile:166: warning: ignoring old commands for target `tac-xml.cgi'
make install-basic
make[2]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6                                             /cgi'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/sbin
for file in *.cgi; do \
                /usr/bin/install -c -m 775 -o nagios -g nagios $file /usr/local/                                             nagios/sbin; \
        done
make[2]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6/                                             cgi'
                /usr/bin/strip /usr/local/nagios/sbin/$file; \
        done
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6/                                             cgi'
cd ./html && make install
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6                                             /html'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/media
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/styles                                             heets
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/contex                                             thelp
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/docs
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/docs/i                                             mages
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/js
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/images
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/images                                             /logos
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/includ                                             es
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/includ                                             es/rss
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/includ                                             es/rss/extlib
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/ssi
/usr/bin/install -c -m 664 -o nagios -g nagios robots.txt /usr/local/nagios/shar                                             e
rm -f /usr/local/nagios/share/index.html
rm -f /usr/local/nagios/share/main.html
rm -f /usr/local/nagios/share/side.html
/usr/bin/install -c -m 664 -o nagios -g nagios jsonquery.html /usr/local/nagios/                                             share
/usr/bin/install -c -m 664 -o nagios -g nagios rss-corefeed.html /usr/local/nagi                                             os/share
/usr/bin/install -c -m 664 -o nagios -g nagios rss-newsfeed.html /usr/local/nagi                                             os/share
for file in *.php; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share; done
for file in stylesheets/*.css; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/stylesheets; done
for file in contexthelp/*.html; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/contexthelp; done
for file in js/*.js; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/js; done
for file in images/*.gif; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/images; done
for file in images/*.jpg; \
for file in images/*.png; \
for file in images/*.ico; \
for file in images/logos/*.*; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/images/logos; done
for file in includes/*.*; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/includes; done
for file in includes/rss/*.*; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/includes/rss; done
for file in includes/rss/extlib/*.*; \
        do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagio                                             s/share/includes/rss/extlib; done
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6/                                             html'
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6                                             '
cp -rf contrib/exfoliation/stylesheets/* /usr/local/nagios/share/stylesheets
cp -rf contrib/exfoliation/images/* /usr/local/nagios/share/images
*** Exfoliation theme installed ***
NOTE: Use 'make install-classicui' to revert to classic Nagios theme
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6'
make install-basic
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/archives
/usr/bin/install -c -m 775 -o nagios -g nagcmd -d /usr/local/nagios/var/spool/ch                                             eckresults
chmod g+s /usr/local/nagios/var/spool/checkresults
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
  make install-init
  make install-config
     - This installs sample config files in /usr/local/nagios/etc
Running configuration check... CONFIG ERROR!  Restart aborted.  Check your Nagio                                             s configuration.
[root@pwnagiosxi1 nagiosxi]# reboot
Broadcast message from [email protected]
        (/dev/pts/0) at 13:44 ...
The system is going down for reboot NOW!
BanditBBS
Re: 2012R2.7 fails to uipgrade to 2014R1.1
Post by BanditBBS »
Verify your config and fix whatever error is listed. You probably have a ghost config file or something.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
KiwiBloke
Post by KiwiBloke »
Results of config verification after i rolled back the upgrade:
looks like 100% heath?
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/pwth1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuild6.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/gwsql8.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtax1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwinfrasql1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwmail2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwendpt2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwword2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwarcsightvm.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtax4.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwad2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwdata2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwiress2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask8.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwvcsvr2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwscm2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw1web5.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwad1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2task4.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2web3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwendpt1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwweb5.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwcompile1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtax7.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2iress1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuildmbc.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2task3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtax5.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwiress1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask5.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuild5.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask7.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask10.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwwsus1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw1sql2a.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuild1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwinfra3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwword1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask4.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwarchive2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtax2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwarcsightvm2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwweb1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuild2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw1web3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw1web6.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwweb3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtax6.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwinfra2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwproxy1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuild4.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwweb2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2web1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtax3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2task2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwftp1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2sql2a.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask9.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwdata1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwinfra5.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtumbleweed.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2task5.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2web2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwinfra1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwproxy3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwav1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwgmc1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2web4.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuild3.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw1web1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwbuild7.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2task1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwweb7.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw2iress2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwweb6.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask6.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw1web2.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pw1web4.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwauth1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwweb4.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwdns1.fnz.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/pwtask11.fnz.com.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_e_lge_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_c.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_IRESS.exe.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_g_lge_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_MEMORY.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_e_med_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_iis_admin.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_f_lge.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_vmtools.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_Alrt.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_ntds.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_ISA.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_Full_Txt_Srch.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_IIS_execution_time.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_L_sml_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_m_lge_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_AD_Connector.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-amd_io-rec.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_Data_Load.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_symantec_ep_mgr_db.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_h_lge_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_e_lge.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_f_lge_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_tumbleweed_ftpd.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-amd_io-sent.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_tumbleweed_admin.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_UPTIME.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_h_lge.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_e_sml.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_i_lge.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_g_lge.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-intel_io-rec.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_IIS_wait_time.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_P_med.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_dns.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_ADWS.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_tumbleweed_database.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_k_lge_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_IIS_queued.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_symantec_11_ep.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_task_scheduler.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_e_med.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_Txt_Indx.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_H_sml_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_Exch_Store_Mgr.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_ESMWorker.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-vmxnet3_io-rec.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_symantec_12_ep.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_iis_www.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Identikey.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_SEPM12_SemSvc.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_conhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-intel_io-sent.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-vmware-PCI-ethernet-io-sent.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_Auth_Virtual_Digipass_MDC.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-vmware-PCI-ethernet-io-rec.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_CPU.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_tumbleweed_sshd.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_vm-vmxnet3_io-sent.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_l_med_sql.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Good_Exch_Sync.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Arc_Mgr_Msg_Retentn_Polcy.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PERF_DISK_p_lge.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_SSH_techtia_service.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_SVC_Auth_Tomcat.cfg'...
Processing object config file '/usr/local/nagios/etc/services/FNZ_PROC_Good_Push_Process.cfg'...
Checking services...
	Checked 624 services.
Checking hosts...
	Checked 86 hosts.
Checking host groups...
	Checked 70 host groups.
Checking service groups...
	Checked 0 service groups.
Checking contacts...
	Checked 3 contacts.
Checking contact groups...
	Checked 2 contact groups.
Checking service escalations...
Checking service dependencies...
	Checked 0 service dependencies.
Checking host escalations...
	Checked 0 host escalations.
Checking host dependencies...
	Checked 0 host dependencies.
Checking commands...
	Checked 109 commands.
Checking time periods...
	Checked 9 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors:   0
Post by slansing »
Yes it does, however it is completely possible the upgrade was bailing because it found a ghost config in the /etc/ directory somewhere, this is new to the core4 verification process. What you could do, (make sure you have your configs backed up) then remove all of the configs from:
And apply configuration, this should rebuild the files there for you. Then try the upgrade again.
KiwiBloke
Post by KiwiBloke »
I just did that and the ../host/ and ../services/ directories were clear before running the "apply configuration" repopulated them (cleanly too I might add)
I reran the upgrade and it failed again at the same point, with the same error. I then rolled the machine back (its the CentOS VM Appliance)
Look like I will have to lodge a formal support request.
Cheers,
C.
edit: spelling and terrible grammer
abrist
Red Shirt
Post by abrist »
The upgrade very well may have completed successfully, and just failed the config verification at the end. Either giv it another try, or open a ticket with [email protected] and we can remote in and assist through the upgrade.
edit: locking as a support ticket has been opened.
