I have found an issue in using snmpv3 in the network/switch monitoring wizard.
We use AuthPriv, with sha and aes-128
the check always leaves out the command switch -x aes so the service check always fails..
network/switch wizard
Re: network/switch wizard
What version of XI are you on, and what version of the wizard are you using? The wizard version can be found in Admin -> Manage Config Wizards.
2014R1.1
Network Switch / Router
Monitor a network switch or router.
Version: 2.0.1
Version: 2.0.1
The updated wizard which contains this fix will be able to be installed when you click "Check for Updates" in Admin > Manage Config Wizards. It will take about 15 or so minutes from now before it will see the new version we uploaded so plan to check around that time.
still not showing up
Grab this and upload it in place. Let us know if that resolves the problem.
