Tried Updating my production Nagios server to 2014 R1.1 today, but the upgrade script failed with the follwoing message:
*** Configuration summary for nrpe 2.15 09-06-2013 ***:
General Options:
NRPE port: 5666
NRPE user: nagios
NRPE group: nagios
Nagios user: nagios
Nagios group: nagios
Review the options above for accuracy. If they look okay,
type 'make all' to compile the NRPE daemon and client.
cd ./src/; make ; cd ..
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nrpe/nrpe-2.15/src'
gcc -g -O2 -I/usr/include/openssl -I/usr/include -DHAVE_CONFIG_H -I ../include -I ./../include -o nrpe ./nrpe.c ./utils.c ./acl.c -L/usr/lib64 -lssl -lcrypto -lnsl -lwrap
gcc -g -O2 -I/usr/include/openssl -I/usr/include -DHAVE_CONFIG_H -I ../include -I ./../include -o check_nrpe ./check_nrpe.c ./utils.c -L/usr/lib64 -lssl -lcrypto -lnsl
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nrpe/nrpe-2.15/src'
*** Compile finished ***
If the NRPE daemon and client compiled without any errors, you
can continue with the installation or upgrade process.
Read the PDF documentation (NRPE.pdf) for information on the next
steps you should take to complete the installation or upgrade.
cd ./src/ && make install-daemon
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/bin
/usr/bin/install -c -m 775 -o nagios -g nagios nrpe /usr/local/nagios/bin
Stopping xinetd: [ OK ]
Starting xinetd: [ OK ]
NRPE installed OK
Upgrading MRTG...
Applying patches to MRTG...
patching file mrtg-2.17.4/bin/cfgmaker
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for perl... /usr/bin/perl
checking for groff... /usr/bin/groff
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for inttypes.h... (cached) yes
checking for unsigned long long... yes
checking for long long... yes
checking for strtoll... yes
checking for printf long long format specifier... %lld
checking for pow in -lm... yes
checking for gdImageGif in -lgd... yes
checking for gdImagePng in -lgd... yes
checking for gdImagePng_jpg in -lgd... no
checking for gdImagePng_jpg_ft in -lgd... no
checking gd.h usability... yes
checking gd.h presence... yes
checking for gd.h... yes
checking the weather... (cached) it's fine
checking if we can use GCC-specific compiler options... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: WARNING: 'Makefile.in' seems to ignore the --datarootdir setting
config.status: creating config.h
ordering CD from http://tobi.oetiker.ch/wish .... just kidding ;-)
Config is DONE!
Type 'make' to compile the software
... that wishlist mentioned above does really exist. So if
you feel like showing your appreciation for MRTG, this is the
place to go. I just love CDs and DVDs
-- Tobi Oetiker <[email protected]>
gcc -g -O2 -Wall -Wpointer-arith -Wcast-align -Wmissing-declarations -Wnested-externs -Winline -W -DHAVE_CONFIG_H -c ./src/rateup.c -o bin/rateup.o
./src/rateup.c: In function update:
./src/rateup.c:1590: warning: comparison between signed and unsigned integer expressions
./src/rateup.c:1627: warning: comparison between signed and unsigned integer expressions
./src/rateup.c:1664: warning: comparison between signed and unsigned integer expressions
./src/rateup.c:1701: warning: comparison between signed and unsigned integer expressions
gcc bin/rateup.o -o bin/rateup -lgd -lpng -lz -lm
/usr/bin/perl -0777 -p -i~ -e "s'^#!\s*/\S*perl'#! /usr/bin/perl'" ./bin/cfgmaker ./bin/indexmaker ./bin/mrtg
/usr/bin/perl -0777 -p -i~ -e 's@GRAPHFMT="...";@GRAPHFMT="png";@' ./bin/mrtg ./bin/indexmaker
/bin/sh ./mkinstalldirs /usr/bin
for x in ./bin/mrtg ./bin/cfgmaker ./bin/indexmaker ./bin/mrtg-traffic-sum; do \
/usr/bin/install -c -m 755 $x /usr/bin; done
for x in bin/rateup; do \
/bin/sh ./mkinstalldirs /usr/lib/mrtg2/Pod
mkdir /usr/lib/mrtg2
mkdir /usr/lib/mrtg2/Pod
for x in ./lib/mrtg2/*.pm; do \
/usr/bin/install -c -m 644 $x /usr/lib/mrtg2; done
for x in ./lib/mrtg2/Pod/*.pm; do \
/usr/bin/install -c -m 644 $x /usr/lib/mrtg2/Pod; done
/bin/sh ./mkinstalldirs /usr/share/mrtg2/icons
mkdir /usr/share/mrtg2
mkdir /usr/share/mrtg2/icons
for x in ./images/*.gif ./images/*.png; do \
/usr/bin/install -c -m 644 $x /usr/share/mrtg2/icons; done
/bin/sh ./mkinstalldirs /usr/share/doc/mrtg2
mkdir /usr/share/doc/mrtg2
(cd .; for x in COPYING COPYRIGHT README CHANGES THANKS doc/*.pod doc/*.txt doc/*.png; do \
/usr/bin/install -c -m 644 $x /usr/share/doc/mrtg2; done)
/bin/sh ./mkinstalldirs /usr/share/man/man1
for x in ./doc/*.1; do \
/usr/bin/install -c -m 644 $x /usr/share/man/man1; done
MRTG-POST
Traceback (most recent call last):
File "separate_mrtg_cfgs", line 49, in <module>
flush_to_file(BUFFER, CURRENT_CONFIG)
File "separate_mrtg_cfgs", line 16, in flush_to_file
temp.seek(0)
AttributeError: 'NoneType' object has no attribute 'seek'I reverted to the VMWare snapshot I took just before the update. Please advise what to do. Tried Googling the error and looked in the forums, but did not find any similar problems.
Grtz
Willem
