I am trialing Nagios Core 4.0.7 on Ubuntu 12.04, with the NSClient++ 0.4.
I have managed to set up the web interface & add 3 PC's (the Nagios Server [localhost], 1 Windows 7 Pro Desktop & 1 Windows Server 2003 VM). The local host PC's services are listed as 'OK'. However, the other 2 PC's which I added have 2 different errors across the board.
The Virtual Machine (with Windows Server 2003 installed) stats look like this:
C:\ Drive Space
CRITICAL 06-11-2014 10:27:57 1d 0h 21m 46s 3/3 Connection refused
CPU Load
CRITICAL 06-11-2014 10:19:09 1d 0h 29m 12s 3/3 Connection refused
Explorer
CRITICAL 06-11-2014 10:21:08 1d 0h 28m 5s 3/3 Connection refused
Memory Usage
CRITICAL 06-11-2014 10:22:19 1d 0h 26m 58s 3/3 Connection refused
NSClient++ Version
CRITICAL 06-11-2014 10:23:30 1d 0h 25m 51s 3/3 Connection refused
Uptime
CRITICAL 06-11-2014 10:24:42 1d 0h 24m 44s 3/3 Connection refused
W3SVC
CRITICAL 06-11-2014 10:25:52 1d 0h 23m 38s 3/3 Connection refused
My Windows 7 machine however throws up a different error, which looks like this:
C:\ Drive Space
CRITICAL 06-11-2014 10:30:32 1d 0h 32m 36s 3/3 CRITICAL - Socket timeout after 10 seconds
CPU Load
CRITICAL 06-11-2014 10:31:43 1d 0h 31m 29s 3/3 CRITICAL - Socket timeout after 10 seconds
Explorer
CRITICAL 06-11-2014 10:22:55 1d 0h 30m 22s 3/3 CRITICAL - Socket timeout after 10 seconds
Memory Usage
CRITICAL 06-11-2014 10:24:06 1d 0h 29m 15s 3/3 CRITICAL - Socket timeout after 10 seconds
NSClient++ Version
CRITICAL 06-11-2014 10:25:18 1d 0h 28m 8s 3/3 CRITICAL - Socket timeout after 10 seconds
Uptime
CRITICAL 06-11-2014 10:26:28 1d 0h 27m 1s 3/3 CRITICAL - Socket timeout after 10 seconds
W3SVC
CRITICAL 06-11-2014 10:27:41 1d 0h 25m 54s 3/3 CRITICAL - Socket timeout after 10 seconds
I have been Googling for most of this week to no avail, so any help with this issue would be brilliant!
Many thanks,
DOL_TECH
CRITICAL - Socket timeout & Connection refused Errors
Dolphin_Tech
rajesh.mehra
Re: CRITICAL - Socket timeout & Connection refused Errors
Please post here your windows host cfg file..
1. Execute check_nt or check_nrpe on CLI.
2. Check nagios client service on windows.
Locking this as it has not been responded to in <5 days, please PM a moderator to get it unlocked if you return.
