Now I thought it may of been a configuration issue with the new core switch we were adding, but then I re-ran on a currently monitored switch and received the same error.No ports were detected on the switch. Possible reasons for this include
What I discovered is that Nagios is not switching to SNMPv2c upon clicking on the v2c tab in the wizard. If I run the command from root with under vers 2, it lists all the ports no problem. But because of this, I can't run the wizard successfully. I search through the forum and saw that you can upgrade the wizards via Admin > Manage Config Wizards > Check for Updates but there are no updates for the wizard.
Any suggestions???
