Need to collect a few short text lists from a few nagios-monitored servers and compare the lists.
Can anyone point me at a doc url on the above?
gather short lists from servers via nagios
smcracraft
- Box293
- Too Basu
Re: gather short lists from servers via nagios
Are you able to elaborate a bit more please.
smcracraft
I have a method to do it, but it's not pure Nagios.
The point is just to gather remote list-based data from systems for verification.
Stuart Watts
If you've already got a script or program that does this, then you won't be too far away from creating a Nagios plugin that you can run as a service at defined intervals, and alert people when the plugin detects something wrong.
Read the Plugin Development Guidelines, which should give you the info you need.
Locking this as it has not been responded to in <5 days, please PM a moderator to get it unlocked if you return.
