Nagios XI 2012R2.9
Offloaded DB
RHEL 6.5 x64
Manual Install
Firefox 29.0.1
Can you please advice how to go about upgrading an offloaded DB?
The current upgrade script does not work and it screwed up my installation.
PHP Warning: mysql_pconnect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /tmp/raja/nagiosxi/nagiosxi/basedir/html/db/adodb/drivers/adodb-mysql.inc.php on line 383
Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support.<br /><br />Run the following from the CLI as root to attempt to repair the DB<br /><br /><pre>/usr/local/nagiosxi/scripts/repair_databases.sh</pre>Checking required prereqs...
Please wait...
I had to restore everything from backup.
Nagios backup & restore scripts is also hardcoded to backup /restore DB's locally.
Please provide a script that works for offloaded DB's.
How to upgrade XI with offloaded DB
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
Re: How to upgrade XI with offloaded DB
I'm anxiously watching this thread as my main XI install uses offloaded DB and I'd like to get it upgraded.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
From my conversations with the support guys, there's not an issue with upgrading an offloaded DB instance.
I have yet to do mine, but the upgrade script pulls DB connect details from the config and updates it accordingly.
Andrew J. - Do you even grok?
But doesnt the update also perform a mysql upgrade? It won't be able to do that remotely, so is there a list of items we need to upgrade on the offloaded db server?
I'd also like for the support guys to chime in here and agree with what vaj said(hopefully) and then answer the ? I just asked
I thought the same as well, but my mysql version is the same on my non-offloaded instance as it is on my offloaded instance. You may want to compare each mysql-related package between your instances as well to doublecheck.
Yes the upgrade script does account for offloaded databases as far as I know, on the point of upgrading mysql, yes, we did upgrade the version of mysql being used by XI in the 2014 releases. That would have to be done manually on the remote database, though you may be able to get away with not doing this if you are exclusively using an offloaded database. I don't *think* we changed any hooks that would require anything pushed in that mysql update. I'll try to set aside some time to test upgrading from 2012 r2.9 with an offloaded database to 2014 r1.1.
I'm trying my server now..I'll report back if I have the same issues as OP or not. (I will have gearman and other issues, but I am prepared for them)
My upgrade went fine with offloaded DB.......just letting you know
Are you using the default passwords in the offloaded DB? Mine is not using defaults.BanditBBS wrote:I'm trying my server now..I'll report back if I have the same issues as OP or not. (I will have gearman and other issues, but I am prepared for them)
RHEL 6 & 7
RHEL 6 & 7
I don't think so actually. Regardless, the update grabs the connection information from /usr/local/nagiosxi/html/config.inc.php
Ok. Obviously there is some problem somewhere else I would not have got the connection error messages.BanditBBS wrote:I don't think so actually. Regardless, the update grabs the connection information from /usr/local/nagiosxi/html/config.inc.php
Does the upgrade script use mysql root? If yes where is it grabbing the info from?
RHEL 6 & 7
RHEL 6 & 7
