[SOLVED] Using plugins that can't be uploaded
cwscribner
Post by cwscribner »
Hi all.
I'm looking to implement a Riverbed Cascade plugin for monitoring but its a .gz file. How do I use something like that? Do I just gunzip it and then copy the file to a particular place?
nscott
Re: Using plugins that can't be uploaded
Post by nscott »
If its simply a plugin, then yes you can just gunzip it and move it to /usr/local/nagios/libexec/ and then setup your command.
Nicholas Scott
