mashckoff
Posts: 1 Joined: Thu Nov 07, 2013 5:55 am
Post
by mashckoff » Thu Jun 12, 2014 10:42 am
Hello
I noticed output from statusjson.cgi is truncated from time to time. I mean the returning json is incomplete, no end of file
....(lot of lines)
"HDD Space": {
"host_name": "pdvlacnx310",
"description": "HDD Space",
"plugin_output": "DISK OK - free space: / 19934 MB (81-371659088node=93%):",
"long_plugin_output": "",
"perf_data": "/=4469MB;20567;23138;0;25709",
"max_attemps": 3,
"current_attempt": 1,
"status": 2,
"last_update": 1400183388000,
"has_been_checked": true,
"should_be_scheduled": true,
Nagios Core 4.0.4 on Red Hat Enterprise Linux Server release 6.4 (Santiago)
Compiled from sources.
I've never seen this. Investigations haven't helped to understand the reason of this and how I can fix it
Vadym Mashkov | Software Engineer | Lviv, Ukraine
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Thu Jun 12, 2014 4:28 pm
Possibly a chatacter in the data being returned needs to be escaped? That character might be causing it to unexpectedly terminate.
Another thing to look at is the amount of data being returned. You might be hitting a limit somewhere.
You might need to contact the author of status-json to see if they can help.
http://exchange.nagios.org/directory/Ad ... on/details
It appears that it hasn't been updated for two years.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
