Upgrade fron 2012r2.9 to 2014 not working
tribbink
Post by tribbink »
I have a similar issue, reagrding post http://support.nagios.com/forum/viewtop ... 5&start=20
My Upgrade from Nagios 2012R2.9 to 2014 lates version also fails, with the same error.
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg --> 0 warning and 0 errors
NDO2DB 1.5.2
Mod gearman is not installed.
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.6'
Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
after the upgrade NagiosXI2014 fails - monitoring Engine wil not start. Error
Have to roll back VMWare snapshot
cat /usr/local/nagios/etc/serviceescalations.cfg
cat /usr/local/nagios/etc/servicedependencies.cfg
Both do not contain data
tribbink
Re: Upgrade fron 2012r2.9 to 2014 not working
Post by tribbink »
Run the Write Config Tool again to check for config errors. If there are no errors, or it's not clear from the output what the errors are, we will have to schedule a remote session to further troubleshoot this issue. You can open a new support ticket in our system by emailing us at [email protected].
i Ran the Write config tool, no errors, Opening a support ticket is not possible because of no support contract.
We just updated our FAQ wiki page, pertaining to the 2014 upgrade issues.
http://support.nagios.com/wiki/index.ph ... 14_Upgrade
Please, let us know if this helped.
