Lost services when upgrade failed
rickwilson7425
Post by rickwilson7425 »
I tried to run the upgrade from 2014R1.0 to R1.1 and it failed.
I restored from tape backup but now I only have a few services displaying whereas I had about 40 or so before. This is on my test migration system so fortunately there aren't that many active servers or services on it.
The write and verify of configuration come up clean but it only writes 8 services for 10 hosts. The hosts and all their services are marked as active in CCM.
Re: Lost services when upgrade failed
Post by Box293 »
Try deleting all the host and service definition flat files.
rm -f /usr/local/nagios/etc/services/*.cfg
rm -f /usr/local/nagios/etc/hosts/*.cfg
Once you've done this, go into CCM and under Quick tools click Apply Configuration (this will re-create all of the host and service definition flat files).
Did this fix your problem?
rickwilson7425
That did not help.
Odd thing about this is that I can use the Write Config tool and I get no errors. If I use the Apply Configuration tool it fails.
Post by slansing »
What does the apply configuration tell you specifically when it errors out? There is a possibility that it is spitting out a DB error as opposed to a configuration error.
rickwilson7425
It says:
Applying Configuration
Command submitted for processing...
Waiting for configuration verification.................................................................
Configurations failed to write to file.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Please apply config again, after the failure go to CCM->Monitoring Config Snapshots (on the left)->from the top red line, open the second icon from the left (should look like a piece of paper with a small corner folded). Paste the output from that file into the forum. Please remember to use
 wraps for large output or just attach instead of pasting.
rickwilson7425
This is the list of config snapshots:
Date Snapshot Result File Actions
06/17/2014 08:00:01 Config Ok 1403013601.tar.gz Download View Output Restore Archive
06/16/2014 07:59:01 Config Ok 1402927141.tar.gz Download View Output Restore Archive
06/15/2014 07:58:01 Config Ok 1402840681.tar.gz Download View Output Restore Archive
06/14/2014 07:57:02 Config Ok 1402754222.tar.gz Download View Output Restore Archive
06/13/2014 07:56:02 Config Ok 1402667762.tar.gz Download View Output Restore Archive
06/12/2014 07:55:02 Config Ok 1402581302.tar.gz Download View Output Restore Archive
06/11/2014 07:54:01 Config Ok 1402494841.tar.gz Download View Output Restore Archive
05/28/2014 12:06:23 Config Error 1401300383.tar.gz Download View Output Delete
05/28/2014 12:04:45 Config Error 1401300285.tar.gz Download View Output Delete
05/28/2014 10:27:38 Config Ok 1401294458.tar.gz Download View Output Restore Archive
05/28/2014 10:27:08 Config Error 1401294428.tar.gz Download View Output Delete
05/28/2014 10:24:01 Config Ok 1401294241.tar.gz Download View Output Restore Archive
05/28/2014 10:23:10 Config Ok 1401294190.tar.gz Download View Output Restore Archive
05/23/2014 10:47:25 Config Error 1400863645.tar.gz Download View Output Delete
05/22/2014 10:04:45 Config Error 1400774685.tar.gz Download View Output Delete
05/22/2014 10:03:49 Config Error 1400774629.tar.gz Download View Output Delete
05/22/2014 09:57:46 Config Error 1400774266.tar.gz Download View Output Delete
05/22/2014 09:55:06 Config Error 1400774106.tar.gz Download View Output Delete
05/22/2014 09:54:01 Config Error 1400774041.tar.gz Download View Output Delete
05/22/2014 09:53:40 Config Error 1400774020.tar.gz Download View Output Delete
As you can see there isn't a failure file to open at the top of the list.
Here is what the config snapshot at the top of the list says:
Nagios Core 4.0.6
Last Modified: 04-29-2014
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 11 services.
Checked 10 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 194 contacts.
Checked 34 contact groups.
Checked 176 commands.
Checked 9 time periods.
Checked 0 host escalations.
Checked 10 hosts
Checked 0 host dependencies
Checked 9 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Post by Box293 »
Can you please tell us what the Error is in this snapshot file or attach it please?
rickwilson7425
I fixed the error that it indicates.
It says:
Nagios Core 4.0.5
Last Modified: 04-11-2014
License: GPL
Error: Unexpected start of object definition in file '/usr/local/nagios/etc/commands.cfg' on line 339. Make sure you close preceding objects before starting a new one.
Post by Box293 »
rickwilson7425 wrote:I fixed the error that it indicates.
Did you resolve this or do you still need help?
If you need help, please attach the file '/usr/local/nagios/etc/commands.cfg'
