Is it possible to make an acknowledgment non sticky by default? If yes, would it be possible to make acknowledgments non-sticky by default only for warnings?
Grtz
Willem
Non Sticky Acknowledgments
Nagios XI 5.8.1
https://outsideit.net
Re: Non Sticky Acknowledgments
I believe you can do it only if you remove the "CHECKED" from the line 979 in the "cmd.c" file, and recompile Nagios Core. I haven't tried it. It may work but I don't recommend it. It won't work "selectively" for warnings only, either.
Hmm never mind then.. Recompiling Nagios Core is not something on my to do list. I'll manage without.
Thanks for the information. Thread can be closed.
Nagios XI 5.8.1
