Problem with Auto-Discovery
ditlevw
Post by ditlevw »
Hi
I can't find anyone else who has the same problem as me, so here you have a thread about my problem with Auto-Discovery.
I've setup Auto-Discovery to scan a subnet on my network. On this subnet, I have both network-devices and the IP of my own PC. Even though I leave Auto-Discovery to search a small part of the network, perhaps just a /27 (ex 10.0.0.0 255.255.255.224), It doesn't find anything. The Auto-Discovery doesn't seem to end the search even if I leave it for hours. One could think, that it could have something to do with access-lists or firewalls, but it isn't that. If I run a normal "manual" Monitoring Wizard, it finds my device in a second.
I've tried to capture the trafic from Nagios XI to my computer and I can see that Nagios does try to check on a lot of open ports, but I still don't get why the Auto-Discovery doesn't finish.
Does anyone else have the same problem?
I'm running Nagios XI 2011R1.5 on a virtual server in an ESX-environment. The license is just "trial" with the ability to monitor up to 7 devices.
I'm wondering if it might have something to do with the devices that doesn't disapear from "Host Detail", even if they have been deleted from the "Hosts" -list in Nagios Core Config Manager.
I'm really in doubt if Nagios is the right thing for a Linux-newbie like me. If you have to be a Linux-expert to fix problems like this, it might be difficult to get customers.
Ditlev - Nagios newbie
Nagios XI, 2011R1.6, 32bit
Operating system
LSB Version: :core-4.0-ia32:core-4.0-noarch:graphics-4.0-ia32:graphics-4.0-noarch:printing-4.0-ia32:printing-4.0-noarch
CentOS release 5.6 (Final)
ditlevw
Re: Problem with Auto-Discovery
Post by ditlevw »
Oh.... I forgot to mension that, the installation is from a 32-bit VM-ware image.
Operating system
siju.doniston
Post by siju.doniston »
Hi
I am also facing this same issue.When i run the network scan ex 191.168.1.0/24 , it detect nothing
Any help would be appreciated.
thanks
Siju
ditlevw
Post by ditlevw »
ditlevw wrote:...
As for the devices that still appear in my "Host Detail", I can add that I currently have 6 hosts, according to the License Information.
Operating system
ditlevw
Post by ditlevw »
Is everyone on vacation?
Operating system
Try to run fping manually, for example (plug in your IP/subnet):
# fping -a -A -d -g 191.168.1.0/24
ditlevw
Post by ditlevw »
lmiltchev wrote:Try to run fping manually, for example (plug in your IP/subnet):
Done. I got replys from the devices I expected.
Could it have something to do with what I mentioned earlier about the devices that doesn't disapear from "Host Detail", but are deleted from the "Hosts"-list in the Core Config Manager?
Operating system
ditlevw
Post by ditlevw »
:roll:
Operating system
nscott
Post by nscott »
I'm currently doing some testing on this component/wizard. There was a bug in this component/wizard several weeks ago. There is phantom bug where the wheel will keep spinning and all you'll need to do is hit the refresh job list.
If you have some sort of IDS and packet sniffer that could be in issue as well, since fping and then the corresponding port check would definitely raise some IDS alarms.
Nicholas Scott
ditlevw
Post by ditlevw »
nscott wrote:I'm currently doing some testing on this component/wizard. There was a bug in this component/wizard several weeks ago. There is phantom bug where the wheel will keep spinning and all you'll need to do is hit the refresh job list.
I don't have any IDS ...yet.
Operating system
