Seperating /usr partition
narayanamoorthys
Post by narayanamoorthys »
My /usr was under / partition and due to space crunch i had to move /usr to a new partition booting thru rescue mode. Copied all files from /usr to /usr1 and renamed /usr1 in rescue mode.
After rebooting everything is fine... Nagios, Postgresql & Mysql are up and service checks are fine. Admin->System Status show all components are good. But not able to see any performance graphs of any monitors. They are just blank.
Appreciate any help. TIA.
Re: Seperating /usr partition
Post by slansing »
Did you change the location of the original directories:
/usr/local/nagios/share/perfdata/
And:
/var/lib/mrtg/
Is this for all hosts/services, or only a select number? Do you see perfdata that stops at the time when you switched the partition name over on the graphs?
abrist
Red Shirt
Post by abrist »
First, try restarting npcd as it may be pointing to old inodes:
service npcd restart
Start troubleshooting by checking the logs for errors. Enable logging by following the FAQ:
http://support.nagios.com/wiki/index.ph ... leshooting
Then run a tail of the following logs and post them here:
tail -25 /usr/local/nagios/var/npcd.log
tail -25 /usr/local/nagios/var/perfdata.log
If you notice any load_threshold or TIMEOUT issues, see the following FAQ entries:
http://support.nagios.com/wiki/index.ph ... ta_Timeout
http://support.nagios.com/wiki/index.ph ... _Threshold
EDIT: Also, did you preserve permission when you copied /usr?
narayanamoorthys
The problem is due to more number of on xipde folder. Removing after the folder as mentioned in FAQ everything is fine.
The FAQ helped a lot. Thanks.
abrist
Red Shirt
Post by abrist »
No problem. I think I will move the xidpe faq entry up into the main perfdata section and generalize it as it applies to all releases. Thanks for the feedback, cheers!
