I'm attempting to limit the number of processes that Nagios XI 2014 will place against a remote server. Are there any nagios.cfg settings that limit processes, workers, etc? I have removed Mod Gearman which I was able to limit worker processes available. I'm hoping there is a configuration setting within Nagios that will do the same?
Thanks, Marcus
Nagios XI 2014 - How Do You Throttle Down Workers?
sreinhardt
- -fno-stack-protector
Re: Nagios XI 2014 - How Do You Throttle Down Workers?
Yes there are. You can use the following commands to limit the starting number of workers, and the total number of workers respectively:
core_workers=6
max_concurrent=20Nagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
That worked! Thanks.
I had to change core_workers to check_workers, fyi.
