Disable Outbound Transfers
Fred Kroeger
Post by Fred Kroeger »
Is there a way that I can Disable outbound Transfers from the command line or via the nagios.cfg file?
I'm trying to atomate a DR recovery process so using the GUI is not an option.
regards... Fred
Re: Disable Outbound Transfers
Yes, you would run the following
echo "update xi_options set value='0' where name='enable_outbound_data_transfer';"|psql nagiosxi nagiosxi
And to enable them
echo "update xi_options set value='1' where name='enable_outbound_data_transfer';"|psql nagiosxi nagiosxi
Fred Kroeger
Brilliant! Works perfectly.
Thanks Scott.
