Check for XI updates with a plugin
cwireless
Post by cwireless »
We have this configuration: Nagios XI 2011R1.5
Red Hat Enterprise Linux Server release 5.3; 32 bit; VMWare Image of NagiosXI; No special configurations.Using Mozilla firefox.
We were following this link http://labs.nagios.com/2011/06/14/check ... -a-plugin/
The script is already executable, but we can see this message
[nagios@nagioscwp libexec]$ ./check_xi_updates -c 7
XI Updates UNKNOWN: Failed to check for updates.|'Build Age'=0;;;0;730 'Release Age'=0;;;0;730
Certainly, our last_update_check_succeeded has failed. How can I figure out why?
mguthrie
Re: Check for XI updates with a plugin
Post by mguthrie »
That plugin is still fairly new. Are you able to get a successful update notice from the Nagios XI Admin->Check For Updates page?
cwireless
Post by cwireless »
Hmm,
this is what I get>
Update Check Problem: Last update check failed.
Latest Available Version: 2009R1.3G
Installed Version: 2011R1.5
Last Update Check: 2011-07-14 13:06:48
I have version R1.5, whay the latest available version is R.3G?
FUA
nscott
Post by nscott »
This is something we'll dig into a little deeper, thanks for bringing it to our attention.
Nicholas Scott
cwireless
Post by cwireless »
Our last_update_check_succeeded has failed. How can I figure out why?
nscott
Post by nscott »
Where in the interface are you seeing that it has failed, can you post a screenshot?
Nicholas Scott
cwireless
Post by cwireless »
Attached you will find what you were asking for.
mguthrie
Post by mguthrie »
There's a known bug in 1.6 that causes the update check to fail. We fixed the bug in SVN for the next release. However, the update check may still fail if the XI server is behind a proxy, we're still working on that part.
cwireless
Post by cwireless »
With upgrade R1.7, it is still there at GUI Level.
In Console, the same
[root@nagioscwp libexec]# ./check_xi_updates -c 7
Are you behind a proxy?
