Segfault when Acknowledging
BanditBBS
Post by BanditBBS »
Trying to acknowledge an issue and get a blank screen and this in messages:
Jun 17 13:08:14 svwdcnagios02 kernel: cmd.cgi[2660]: segfault at 38 ip 0000000000411b50 sp 00007fff2c4e26c0 error 4 in cmd.cgi[400000+44000]
Jun 17 13:08:14 svwdcnagios02 abrt[2690]: Saved core dump of pid 2660 (/usr/local/nagios/sbin/cmd.cgi) to /var/spool/abrt/ccpp-2014-06-17-13:08:14-2660 (20365312 bytes)
Mass acknowledge works fine.
EDIT: further testing seems to only have the issue with hosts and not services
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
sreinhardt
-fno-stack-protector
Re: Segfault when Acknowledging
Post by sreinhardt »
We are aware and working on it as I type this out.
BanditBBS
Post by BanditBBS »
sreinhardt wrote:We are aware and working on it as I type this out.
Thanks Spenser!
When completed, if it is just one simple file I'd really love the fix besides a bug fix release as I am gone in a day and no time to update all the servers to yet another new version :(
abrist
Red Shirt
Post by abrist »
Could you PM me the core dump and the cmd.cgi file? It may help speed up Eric[1]'s bug hunt.
BanditBBS
Post by BanditBBS »
The dump is 2.48MB, too large for forum attachment in PM!
EDIT: Also, forget what I said about hosts only. I must have gotten lucky with the service I ack'd as now I can't ack service anymore.
EDIT 2: My other servers are working fine, seems to be just this one
abrist
Red Shirt
Post by abrist »
Send them through email if you could (you should have my email address).
BanditBBS
Post by BanditBBS »
abrist wrote:Send them through email if you could (you should have my email address).
Done, let me know if you do not receive them!
tell this Eric guy to hurry 8-)
BanditBBS
Post by BanditBBS »
Just to throw this out there for troubleshooting. I have been restarting my XI a bunch of times today applying changes. As I stated, it did work for services at one point but then not again. Perhaps restarting the process screws up and/or fixes it every so often. i am going to apply changes a few times to test and will report back.
EDIT: Nope, but it seems randomly I am able to acknowledge some hosts and some services
BanditBBS
Post by BanditBBS »
Just to update anyone watching this......
It is a bug in core 4.0.6 that has been fixed in core 4.0.7. So looks like next XI version(1.2) is needed. Luckily this is only affecting one of my servers and that's because I use a bunch of escalations(for on-call rotation handling) and that's causing the bug. Here's hoping Scott and Eric can somehow hook me up tomorrow :)
Ok, here is a short list of steps to upgrade to Core 4.0.7 on XI 20141.1 before the next XI release, this assumes you have the old installation directory in /tmp/nagiosxi
cd /tmp/nagiosxi/subcomponents/nagioscore/
wget http://sourceforge.net/projects/nagios/files/nagios-4.x/nagios-4.0.7/nagios-4.0.7.tar.gz/download -O nagios-4.0.7.tar.gz
Then edit line 5 of /tmp/nagiosxi/subcomponents/nagioscore/upgrade to read
pkgname="nagios-4.0.7"
Then, edit /tmp/nagiosxi/subcomponents/nagioscore/apply-patches to only contain the following (removing about 5 lines)
#!/bin/sh -e
pkgname="$1"
# Apply our patches
echo "Applying Nagios XI patches to Nagios Core..."
# Custom CGIs
cp patches/cgi/*.c "$pkgname/cgi"
# Makefile mods for Custom CGIs
patch "$pkgname/cgi/Makefile.in" < patches/cgi-makefile.patch
Then, from in the /tmp/nagiosxi/subcomponents/nagioscore/ directory
./upgrade
