I was getting a perl error running this command, which led me to the yum install nagios perl. That led me to the VMware-vSphere-SDK-for-Perl-4.0.0-161974.x86_64.tar.gz install.
There may be, I would highly suggest installing the newest SDK available, as they work with older versions just fine. Also I would suggest following our documentation exactly as written, as this can be a tricky install if you do not.
Yes the were leading you on the right path, but due to vmware's licensing, we can't include the sdk with the XI install.
