Ldap/BIND authentication on Nagios XI
lonewolf1215
I have a setup using Nagios Core in which I have ldap/bind authenticaton being used and setup through the apache/httpd.conf, which works for allowing user authentication using Active Directory. My question is how do I go about setting this up in Nagios XI. I have looked at the component options available and they don't allow for configuring with an AuthLDAPBindDN and AuthLDAPBindPassword for setting up the LDAP Bind username and password. Maybe I'm just looking at the component setups wrong. I want to be able to use the same User and Password that is setup to bind to LDAP in the nagios core setup I'm currently running, but in the Nagios XI Enterprise. Are there any documents as to how an set this up?
Re: Ldap/BIND authentication on Nagios XI
These might be what you are looking for:
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
http://assets.nagios.com/downloads/nagi ... ponent.pdf
