back end login to the core config manager failed.
solrac901
Post by solrac901 »
Linux Distribution and version? cent os
32 or 64bit? 64 bit
VMware Image or Manual Install of XI? vmware virtual machine
Im having issues to monitor my assets the wizard can write in the database i modify the nagios admin user and now i cant use the wizards.
Re: back end login to the core config manager failed.
Post by Box293 »
Try resetting the credentials for CCM.
Admin > System Config > Reset Security Credentials.
Type a new Core Config Manager Admin password and click Update Credentials.
