Nagios Output file
amitdaniel
Nagios Output file
Post by amitdaniel »
Hey Guys ,
Need you professional help again.
I created my own script to nagios with HUGE output (That's fine for me) But nagios Email notification cut the output after the first new line.
This is the example for the output :
Job glowing-indexer-494:bqjob_r4ff798991b23117b_00000146ac7f8634_1
  Job Type    State      Start Time      Duration   Bytes Processed
  load       FAILURE   18 Jun 01:03:04   0:00:00
Errors encountered during job execution. Not found: Google Storage File gs://XXXXXXXXXXXXXXXXXXXXXX.log
info about jobID : bqjob_r603d97f34ad153bf_00000146abac004d_1
Job glowing-indexer-494:bqjob_r603d97f34ad153bf_00000146abac004d_1
Do you think it's possible to send all this to the output ?
Thanks guys !!
chris.fixter
Re: Nagios Output file
Post by chris.fixter »
Does case 3 here http://nagios.sourceforge.net/docs/3_0/pluginapi.html described your case ?
Post by slansing »
As Chris mentioned,
You are going to need to switch from using the normal output macro's to longoutput as shown in Case 3. If you need help with that let us know.
amitdaniel
Thanks for your help but still i can't see my full output .
let me explain what i'm doing (Maybe i have mistakes)
1. Added this file nagios-4.0.7/include/nagios.h
2. Change this variable to this value : #define MAX_PLUGIN_OUTPUT_LENGTH 20192
After that Re-compile the nagios :
1
./configure --with-command-group=nagcmd
2
make all
make install
make install-init
make install-config
make install-commandmode
make install-webconf
Start the nagios.
If i run the script using nagios user this is the output :
[nagios@nagios libexec]$ python check_cloud_watch_test.py
This is the output :
CRITICAL - There is Alarms in Virginia & Europe Regions Please check and fix them => Fusionx_latency ,awselb-fusionx-convfunnel-High-Average-Latency ,
2014-06-18 14:13:08.465651
CRITICAL - There is Alarms in Virginia & Europe Regions Please check and fix them => awselb-fusionx-convfunnel-High-Average-Latency ,
2014-06-18 14:14:48.643213
2014-06-18 14:16:28.835511
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:18:09.011817
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:19:48.174949
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:21:28.300730
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:23:08.486223
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:24:48.776008
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:26:29.093319
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:28:08.437110
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:29:48.694743
OK - No Alarms in Virginia & Europe Regions , Everything is Fine !! 2014-06-18 14:31:28.871091
But in the UI & Email this is what i'm getting :
2014-06-18 14:09:28.765395 (Only the first line)
Thanks for your amazing help like always !!!
sreinhardt
-fno-stack-protector
Post by sreinhardt »
As slansing mentioned, this isn't totally a size issue, but more of after a newline in standard output, the rest is only returned if you request longoutput to be appended to your commands. I would suggest by adding $LONGSERVICEOUTPUT$ to your notification command so that the data after is correctly added to your emails.
amitdaniel
Hey ,
Thanks for your answer but i didn't understand it.
Can you explain to me exactly what i need to change ?
Thanks !!!
chris.fixter
Can you paste your command definition here ?
amitdaniel
NP
        command_name    check_cloud_watch_test
        command_line    /usr/bin/python /usr/local/nagios/libexec/check_cloud_watch_test.py
Let me know if something is wrong ( This is how i define all my commands)
I believe sreinhardt was talking about your notify-service-by-email and notify-host-by-email commands in commands.cfg, and adding the $LONGHOSTOUTPUT$ and $LONGSERVICEOUTPUT$ macros in place of the normal $HOSTOUTPUT$ and $SERVICEOUTPUT$ macros.
amitdaniel
You want to see how i define the service ?
This will help you to help me solved this issue ?
