Whenever i try to restart the nagios service it cames with an error message:
Running configuration check... CONFIG ERROR! Restart aborted. Please check your Nagios configuration files.
The strange thing is that if a run the preflight check it shows 0 errors and 0 warnings.
Does anyone have any idea of what could be causing this?
thanks
Cannot restart Nagios service
Re: Cannot restart Nagios service
Did you install from source or a package? Make sure the verify command it pointing to the main nagios.cfg file to run it's verification against. On a source install the command is:
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg-
tufangursu83
Did you check the user privileges?
