it seems that the output always shows as critical, no matter how many days are left.
./check_domain.php -d gbackit.com -w 30 -c 10
CRITICAL - Domain gbackit.com will expire in 189 days (2014-12-26T00:00:00Z).
check_domain.php
- Box293
- Too Basu
Re: check_domain.php
I'm pretty sure this problem was identified and fixed recently.
Here is the link to the updated version of the plugin:
http://exchange.nagios.org/directory/Pl ... hp/details
And here is the forum thread that reported this problem:
http://support.nagios.com/forum/viewtop ... 16&t=27648
Let us know if that fixes your problem.
yes that fixed the issue. I saw tat there was a 1.1 version and assumed it would be the latest.
Thank you for the response.
Actually I spoke to soon. The new version is working with com/net domain. We have a couple of .CO domains and the bug is still there for those.
Vitaly
Vitaly
sreinhardt
- -fno-stack-protector
Could you post or PM one of us with a domain or two that are failing for .co?
as per request:
./check_domain.php -d gravitas.co -w 30
WARNING - Domain gravitas.co will expire in -16242 days (The expiration date displayed in this record is the date the).
This almost looks like a time setting difference. Are the times and zones set properly on both your Nagios server and on the gravitas.co server you are checking?
I checked and both are correct. The plugin/wizard provides correct time for everything except this one .Co domain.
This seems to be an issue with .co TLDs in general. You did say none of your .co domains are working, correct?
Hi, sorry in delay.
.com, .net and everything else is working. .co on the other hand is giving this error.
