Nagios 2014R1.1 upgrade errors w/ verification
btmikkelsen
Post by btmikkelsen »
Having trouble applying config after upgrade. there were about 20 services that lost their host/hostgroup associations - I fixed those. The current status is it is not applying, but it is not giving any reason why.
I've included the ndo2db | head -2 as you have asked this of others with the same issue.
I've also attached the nagios.cfg
nagios.cfg
[nagios@nanm21 etc]$ /usr/local/nagios/bin/ndo2db | head -2
NDO2DB 2.0.0
[nagios@nanm21 etc]$ /usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg | more
Nagios Core 4.0.6
Last Modified: 04-29-2014
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/viad_servicedependencies.cfg'...
Re: Nagios 2014R1.1 upgrade errors w/ verification
Post by Box293 »
Have a look at the object config file '/usr/local/nagios/etc/viad_servicedependencies.cfg' as this is the last file it processed before the verification failed.
As a test, you could remark out the following line in nagios.cfg
cfg_file=/usr/local/nagios/etc/viad_servicedependencies.cfg
Then run this command again and see if the error occurs:
Let us know how that goes.
btmikkelsen
Same error with that line quoted out.
btmikkelsen
I took all the config files out, line by line - the problem is with serviceescalations. We have this in our service escalations:
define serviceescalation {
service_description Avaya CM Alarm,PROD:CORE:Main Web Page
contacts Escalation DL
first_notification 1
last_notification 0
notification_interval 15
escalation_period 24x7
escalation_options c,r,
service_description Avaya CM Alarm,PROD:TELECOM:Meeting Exchange,PROD:TELECOM:SIP
contacts network
last_notification 0
I've inactivated these for now, but would like to know what is the problem with them? So - we are working again post-upgrade with these inactivated
You are missing the "host_name" directive, which is required...
http://nagios.sourceforge.net/docs/nagi ... escalation
btmikkelsen
Thank you. that makes sense. Just like some of the services lost their host_group and I had to add them back. Thank you!
Is it safe to lock this thread up?
