I have noticed a problem when adding or re-configuring a host. The Waiting for configuration verification part hangs and fills the screen with .......... The funny thing is that the change does take effect, the host gets added or reconfigured normally but the screen continues to fill with dots. For some reason this only occurs on Macs, we have tried different machines and both Safari and Chrome with the same results. I am able to complete the same task on my windows machine without a problem. Are there any known compatibility issues with the UI on Macs? A silly question I know..... but i cant replicate the problem otherwise.
Waiting for configuration verification..... on Mac.
Re: Waiting for configuration verification..... on Mac.
Good to know, javascript can be interpreted differently in both browsers and OSes, so we'll see what we can figure out for it. We did have a known issue with this in 1.3 though, are you using 2011R1.5?
