Nagios Core 4.0.6
Last Modified: 04-29-2014
License: GPL
Reading configuration data...
Read main config file okay...
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/FTP.cfg', starting on line 44)
When I run /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfv I get:
Now the original error shows an issue on line 44. Here is those definition:Website: http://www.nagios.org
Warning: Duplicate definition found for service 'Fans' on host 'EQL-ARY-Stack' (config file '/usr/local/nagios/etc/services/EQL-ARY-Stack.cfg', starting on line 78)
Checking objects...
Checked 1041 services.
Checked 89 hosts.
Checked 26 host groups.
Checked 15 service groups.
Checked 9 contacts.
Checked 5 contact groups.
Checked 132 commands.
Checked 14 time periods.
Checked 0 host escalations.
Checked 89 hosts
Checked 0 servicedependenciesCode: Select all
Checked 0 host dependencies
Checked 14 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
host_name dc01-ftp-03
service_description ftp-03 - FTPS List
use xiwizard_nrpe_service
servicegroups FTP
check_command check_ftps!test!vfm11test!21!dc01-ftp-03.prod-cloud.com!!!!
max_check_attempts 3
check_interval 5
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard linux-server
register 1
