I upgraded Nagios to the latest version and was greeted with a fabulous error;
Reading configuration data...
Read main config file okay...
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/Basic_Windows_Uptime.cfg', starting on line 14)
If I manage to clear the first error rest assured there will be another right behind it as I try to apply the configuration. I have been looking at this for 2 days to no avail. Can you please advise on an appropriate course of action? We have a current support contract.
After Upgrade numerous errors
Re: After Upgrade numerous errors
The trick is to not "apply config" until a "write" and "verify" (from the write config tool) report no errors. See the following FAQ entry:
http://support.nagios.com/wiki/index.ph ... 14_Upgrade
Thank You Ill look at it
