XI and PagerDuty
rickwilson7425
XI and PagerDuty
Post by rickwilson7425 »
We are working on migrating from Core to XI. We already use PagerDuty with Core. Will the commands and settings migrate to XI when we import the config files?
Re: XI and PagerDuty
Assuming you use the same plugin, commands, and arguments, and assuming you follow the proper import procedure, I see no reason why it would not still work.
What specifically are you using right now to integrate? Just notification commands and/or event handlers?
rickwilson7425
I'm not sure actually.
Here is the command string for "notify-service-by-pagerduty":
/opt/omd/sites/prod1/local/bin/notifiers/pagerduty_nagios.pl enqueue -f pd_nagios_object=service
sreinhardt
-fno-stack-protector
Post by sreinhardt »
I would probably suggest copying that plugin to /usr/local/nagios/libexec and altering your command to use $USER1$/pagerduty_nagios.pl, but otherwise I doubt you need to make many if any other changes. We definitely have others using pagerduty and from all accounts it works great with both XI and Core.
