Hello all I hope this is the correct place to put this question.
I'm pretty new at Nagios and would like to know if there is a way to set a custom notification template for a specific service alert that will email to specific user(s).
eg
My computer goes down -> IsaacCompDownEmailTemplate -> Email Isaac only
Let me know if that does not make sense I can give another example. Clearly this wouldn't be for my specific machine but for a service on one of our servers.
Isaac
Notification question
Re: Notification question
Yes, this is part of the basic functionality of Nagios. You will want to start with http://nagios.sourceforge.net/docs/3_0/ ... tions.html on how notifications work, and then you will want to use a service_notification_commands and/or host_notification_commands for the specific contact, to use a different notification generation technique than your "normal" notification. Those attributes are part of the contact, so you'll want to read up on http://nagios.sourceforge.net/docs/3_0/ ... ml#contact.
Currently you probably have something in commands.cfg that looks like this:
You could make a similar one like this:
then just use notify-isaac-by-email for the services you want the custom email on. If you want to have a single service send a normal email to some people but a specialized email to you only, you would need to write a wrapper script that checks to see who is being notified and take action accordingly. Still doable, just a bit more work.
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_name notify-isaac-by-email
Thanks for the quick replies.
I went in and added the notify-isaac-pc-down section. That was easy... The part im having trouble with is how do I directly assign that notify to a specific host or service.
I need it to send that template to the "overnightreps" Contact when the service "Check_Asterisk_CDR" fails or goes down. Im just not sure where to put the "check_asterisk_cdr 1(enable)"
Does that make sense? I guess I don't know if I have to add a line to a service, host, service group, contact etc.. for nagios to know that when cdrs go down to email the over night reps and me. I don't need the reps getting alerts for everything else.
Isaac
Isaac
To quote myself:
- First, you need to create the specific notification command. By your posting, it looks like you've done that.
Then you need to modify your "issac" contact to use a service_notification_commands and/or host_notification_commands of your new "notify-isaac-by-email" command.
Then make sure your service and/or hosts use the "issac" contact
