I'm getting these errors when testing restore of tar.gz file archived by backup_xi.
The source machine is 64bit and the destination is 32bit. Is this a known issue?
-klee
[root@bcsnsnagiostest1 ~]# /usr/local/nagiosxi/scripts/restore_xi.sh nagiosxi.1403755141.tar.gz
WARNING: you are trying to restore a 64-bit backup on a 32-bit system
Plugins and other binaries will NOT be restored.
Are you sure you want to continue? [y/N] y
TS=1403759428
Extracting backup to /store/backups/nagiosxi/1403759428-restore...
tar (child): nagiosxi.1403755141.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
In /root...
Unable to find files to restore in /root
restore_xi failed
Re: restore_xi failed
Yes, you are restoring from a 64 bit server to 32 bit. It's not an issue, it's a matter of bits and bytes
You will not be able to restore some portions of your backup due to trying to put it on a 32-bit system as noted below. There is a warning about this that is part of the restore_xi.sh script so yes, we do know about the implications of this. You will also have trouble restoring your RRD files (contain performance data) to a different architecture. My suggestion, is to restore to a 64 bit system. If you are really downgrading to a 32-bit one, then you will have a bit of work ahead of you with turning it into an XI server with the old data, which we can help you with.
Thanks slansing.
We'll be sure to restore to 64bit system.
-klee
-klee
Sounds good! That will save you a lot of time, we will keep this thread open for if you have issues.
It's OK, please close this thread for now.
We know what we have to do.
-klee
-klee
