I have followed quick installation guide: http://nagios.sourceforge.net/docs/3_0/ ... nsuse.html to set up initially.
But i ended up with a problem to access index.php file in browser after modifying the nagios.conf as mentioned below.
# SAMPLE CONFIG SNIPPETS FOR APACHE WEB SERVER
# Last Modified: 11-26-2005
# This file contains examples of entries that need
# to be incorporated into your Apache web server
# configuration file. Customize the paths, etc. as
# needed to fit your system.
# SSLRequireSSL
Options ExecCGI
# Options +Indexes FollowSymlinks +ExecCGI
AllowOverride None
# AllowOverride Indexes AuthConfig FileInfo
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
AuthName "Nagios Access"
AuthType Basic
AuthUserFile /usr/local/nagios/etc/htpasswd.users
Require valid-user
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
# SSLRequireSSL
DirectoryIndex index.php
Options None
# Options +ExecCGI
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
AuthType Basic
Require valid-user
</Directory>Some one could suggest me ti fix it.
Please share latest installation guide for nagios core 4x in SUSE 11 and suggest me appropriate plugins to add and check status of multiple hosts in HUB .
