i just noticed that for all our servers (windows) the performance graphs for the disk usage are not longer showing.
Under the advance tap i can still see the perfdata but no graphs are available any longer.
For all other services the graphs are looking fine.
Advanced Status Details
Service State: Ok
Duration: 4d 18h 34m 26s
State Type: Hard
Current Check: 1 of 5
Last Check: 06/29/2014 08:08:05
Next Check: 06/29/2014 08:13:05
Last State Change: 06/24/2014 13:35:31
Last Notification: Never
Check Type: Active
Check Latency: 0 seconds
Execution Time: 0.0099 seconds
State Change: 0%
Performance Data: 'C:\ Used Space'=37.81Gb;39.92;47.40;0.00;49.90regards
Matt
