Lame Service definition Warning?
rajasegar
Post by rajasegar »
Nagios Xi Ent Ed 2014R1.2
Can someone advice me what is this lame definition warning?
Warning: Ignoring lame service dependency (config file '/usr/local/nagios/etc/servicedependencies.cfg', line 69)
define servicedependency {
dependent_service_description MIMIX Repl Group2
host_name MY1PIRR1
service_description MIMIX Repl Group1
inherits_parent 1
execution_failure_criteria n,
notification_failure_criteria n,
dependency_period 24x7
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
Re: Lame Service definition Warning?
I believe you are missing the dependent_host_name:
http://nagios.sourceforge.net/docs/3_0/ ... dependency
sreinhardt
-fno-stack-protector
Post by sreinhardt »
The only thing you are missing, is a dependent_host_name, which is likely why you are getting a warning.
dependent_host_name: This directive is used to identify the short name(s) of the host(s) that the dependent service "runs" on or is associated with. Multiple hosts should be separated by commas. Leaving this directive blank can be used to create "same host" dependencies.
rajasegar
Post by rajasegar »
Thanks guys. Will look into it in the morning.
RHEL 6 & 7
rajasegar
Post by rajasegar »
       dependent_host_name                      MY1PIRR1
       host_name                                MY1PIRR1
       inherits_parent                          1
Still the same lame warning for the above. I already applied the Configurations.
I have a bunch of dependencies without dependent_host_name and no warning
       dependent_service_description            Thread: ORB.thread.pool
       host_name                                esbwasp01,esbwasp02
       service_description                      Thread: MessageListenerThreadPool
       inherits_parent                          1
       execution_failure_criteria               u,c,
       notification_failure_criteria            u,c,
RHEL 6 & 7
       host_name                                MY1PIRR1
       inherits_parent                          1
You have the dependent_host_name set the same as the host_name:
host_name: This directive is used to identify the short name(s) of the host(s) that the service that is being depended upon (also referred to as the master service) "runs" on or is associated with. Multiple hosts should be separated by commas.
Does the message still point you to line 69?
Is the servicedependency definition that you showed us copied from the CCM (View Text Config) or from the actual config (/usr/local/nagios/etc/servicedependencies.cfg)?
rajasegar
Post by rajasegar »
       host_name                                MY1PIRR1
       inherits_parent                          1
Initially dependent_host_name was left blank and I changed it after you advised it was missing.
RHEL 6 & 7
rajasegar
Post by rajasegar »
It is pointing to the same line and the definition came from usr/local/nagios/etc/servicedependencies.cfg.
Where is this CCM (View Text Config) located. I just cannot seem to find it. :shock:
RHEL 6 & 7
Right about here:
