NRPE rpm install
BanditBBS
NRPE rpm install
Post by BanditBBS »
I have been searching for an hour now with no luck. Anyone have a link to an rpm install of NRPE that was created with command line arguments allowed?
Thanks!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
sreinhardt
-fno-stack-protector
Re: NRPE rpm install
Post by sreinhardt »
Our rpm spec for nrpe enables command args by default. I take it repos and distros are choosing to disable this? You should be able to use the following steps to build one:
cd /tmp
wget https://github.com/NagiosEnterprises/nrpe/archive/nrpe-2-14.tar.gz
rpmbuild -ta nrpe-2-14.tar.gz
I forget if it puts the rpm next to the tar on the filesystem or if it places it in some internal cache, but a locate or find should be able to find it.
