a report with graphs of output?
devildog31415
Post by devildog31415 »
I would like to receive a report weekly with the graphs from my temp/humidity sensors so I can see what the week looks like without going in and viewing the host graphs manually.
Can I do that? it seems like all the reports are centered around graphing that an alert happened, nothing around graphing the history of a reading.
If it's there, I'm being dense.
Re: a report with graphs of output?
Go to Reports -> Availability and choose your host from the dropdown. Click the "Show Advanced Options" link and check the "Display service performance graphs" box, then hit Update. You can view a PDF of this report by clicking the PDF button on the right. This report can be scheduled as part of the Enterprise Edition features.
I've attached a sample PDF from my own localhost (just change extension to pdf).
