I am having some problems with:
./check_snmp
Error:
External command error: Timeout: No Response from 192.168.0.29:161
From my Nagios server I can successfully snmpwalk the host 192.168.0.29:
[root@hq-nagios-02 libexec]# snmpwalk -v 2c -c 'xxxxxxx' 192.168.0.29 | more
SNMPv2-MIB::sysDescr.0 = STRING: Linux hq-schd-01.myvest.com 2.6.32-358.11.1.el6.x86_64 #1 SMP Wed Jun 12 03:34:52 UTC 2013 x86_64
SNMPv2-MIB::sysObjectID.0 = OID: NET-SNMP-MIB::netSnmpAgentOIDs.10
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (62844) 0:10:28.44
SNMPv2-MIB::sysContact.0 = STRING: Anton Zavrin (configure /etc/snmp/snmp.local.conf)
SNMPv2-MIB::sysName.0 = STRING: hq-schd-01.myvest.com
SNMPv2-MIB::sysLocation.0 = STRING: Quest, Atlanta, GA (edit /etc/snmp/snmpd.conf)
SNMPv2-MIB::sysORLastChange.0 = Timeticks: (2) 0:00:00.02
SNMPv2-MIB::sysORID.1 = OID: SNMP-MPD-MIB::snmpMPDMIBObjects.3.1.1
SNMPv2-MIB::sysORID.2 = OID: SNMP-USER-BASED-SM-MIB::usmMIBCompliance
SNMPv2-MIB::sysORID.3 = OID: SNMP-FRAMEWORK-MIB::snmpFrameworkMIBCompliance
SNMPv2-MIB::sysORID.4 = OID: SNMPv2-MIB::snmpMIB
SNMPv2-MIB::sysORID.5 = OID: TCP-MIB::tcpMIB
From that same host I an snmpwalk localhost successfully.
[root@hq-schd-01 snmp]# snmpwalk -v 2c -c 'xxxxx' localhost | more
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (67509) 0:11:15.09
Problem is now when I use the check_snmp script on my Nagios server I am getting the following error:
[root@hq-nagios-02 libexec]# ./check_snmp -H 192.168.0.29 -C 'xxxxxxx' -o ".1.3.6.1.2.1.25.6.3.1.4.159"
External command error: Timeout: No Response from 192.168.0.29:161.
I have tried all sorts of iterations of the check_snmp command with different parameters, however, still not able to get this to work ?
Nagios Server is running Nagios Core 4.0.7 on CentOS:
[root@hq-nagios-02 libexec]# cat /etc/issue
CentOS release 6.5 (Final)
Kernel \r on an \m
Client machine is also CentOS:
root@hq-schd-01 snmp]# cat /etc/issue
CentOS release 6.4 (Final)
Kernel \r on an \m
Any thoughts / help much appreciated!!!
I am able to execute external commands from the web interface!
Thank you,
John Dworske
