scheduled report pdf broken
devildog31415
I get the attached error. i'm on the latest version of xi.
Re: scheduled report pdf broken
Are you using SSL? What version of Nagios XI is this on? Can you show what you have in the Admin > System Settings > Program/External URL fields?
Also, when trying to create a PDF from the Reports menu, is it also corrupted or is this only happening with emailed pdf reports?
devildog31415
- I am not using SSL
- ver 2014R1.2
- http://<IP>/nagiosxi/
- yes the PDF displays if I run it in the window and I can hit "save" and it opens fine after downloading
- ver 2014R1.2
Let's verify - you have the following text in the "Program URL" field:
Do you have anything in the "External URL"?
Are you having issues with Capacity Planning reports only or with all of the reports? Are you using a proxy?
http://<IP>/nagiosxi/Are you having issues with Capacity Planning reports only or with all of the reports? Are you using a proxy?
