check_nrpe Unable to read output
akepley
Post by akepley »
I just upgraded to 2014R1.2
I created a new monitored host and services and some of the services (specifically yum, memory, and CPU) are coming back "Unknown: NRPE: Unable to read output".
I have tried the following:
checked the client nrpe.cfg file:
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
        flags           = REUSE
        socket_type     = stream
        port            = 5666
        wait            = no
        user            = nagios
        group           = nagios
        server          = /usr/local/nagios/bin/nrpe
        server_args     = -c /usr/local/nagios/etc/nrpe.cfg --inetd
        log_on_failure  += USERID
        disable         = no
        only_from       = 172.16.17.95
Checked the scripts:
-rwx------. 1 root   root     3060 Jun 23 14:24 custom_check_mem
Notice this check requires sudo, so I added to the sudoers file for nagios user:
Defaults:nagios !requiretty
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/custom_check_mem
Nothing has changed the output of the original error:
Memory Usage;UNKNOWN;SOFT;3;NRPE: Unable to read output
Re: check_nrpe Unable to read output
Can you post the custom_check_mem file? I am guessing that calls check_nrpe, but if that is the case is there any reason you have a wrapper?
akepley
Post by akepley »
I'm sorry, I'm misunderstanding. Do you want me to post the file contents for the custom_check_mem file from the client server under /usr/local/nagios/libexec?
Post by Box293 »
Yes, please attach the custom_check_mem file from the client server (you might need to give it a .txt extension).
akepley
Post by akepley »
File Attached
Are any of your NRPE checks working or is it just this one failing?
akepley
Post by akepley »
Just a few of the services. See the attached screenshot.
abrist
Red Shirt
Post by abrist »
I presume the monitored server is cent/rhel? Can you run the check from the cli?
akepley
Post by akepley »
The monitored server is a VM on VMWare running RHEL.
As nagios user running the custom_check_mem I get permission denied on the monitored server. This is after I have added the following to sudoers:
Post by slansing »
Hmm permission denied eh? How were nrpe and the nagios plugins package installed on this system? Did you just use the xi-linux-agent guide? What is the output of the following when ran on that system?:
ll /usr/local/nagios/libexec/
