I have read the FAQs about the know issues about how to approach this, but I don't get any further.
When I Write Database Configs To File I the following error:
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/Internet-diensten.cfg', starting on line 14)
Nagios Core 4.0.7
Last Modified: 06-03-2014
License: GPL
Reading configuration data...
Warning: use_embedded_perl_implicitly is deprecated and will be removed.
Warning: sleep_time is deprecated and will be removed.
Warning: p1_file is deprecated and will be removed.
Warning: external_command_buffer_slots is deprecated and will be removed. All commands are always processed upon arrival
Warning: enable_embedded_perl is deprecated and will be removed.
Warning: command_check_interval is deprecated and will be removed. Commands are always handled on arrival
Read main config file okay...
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/hosttemplates.cfg', starting at line 14)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/hosttemplates.cfg', starting at line 136)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/servicetemplates.cfg', starting at line 14)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/servicetemplates.cfg', starting at line 137)
Can you please post /usr/local/nagios/etc/services/Internet-diensten.cfg or at least show us line 14? It looks like you just need to provide a service description.
# Service configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2014-07-07 14:16:23
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
service_description ServiceNetwerk
notifications_enabled 1
register 1
# END OF FILE
Looks like that service has not been assigned to a host, it was likely a ghost service who's host was removed previously but it stayed around as a flat config file. You can remove this service and re run the upgrade:
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
slansing wrote:Looks like that service has not been assigned to a host, it was likely a ghost service who's host was removed previously but it stayed around as a flat config file. You can remove this service and re run the upgrade:
Nagios cannot start or restart with a bad configuration. You need to use the Write Config Tool to check for config errors:
CCM->Tools->Write Config Files->Write->Verify
If you find config errors, you need to fix them, then run the Write Config Tool AGAIN, as you may have more errors. Run the Write Config Tool as many times as you need to. Once, ALL of the config errors have been fixed, you can apply configuration.
Do you have any config errors now when you run the Write Config Tool?
Because of limited time had to cancel the upgrade, and rolled back the snapshot of the server. I will start a copy of this server soon to follow your advice. Thanks for your support.
