Email notifications not working
vmesquita
Post by vmesquita »
It's been about 10 days that Nagios doesn't send any notifications. I checked the SMTP server and it's ok. I was also able to manually send email connecting with telnet with no issues.
Here's a extract from /var/log/maillog:
Jul  8 14:25:01 nagios postfix/qmgr[2259]: 9E478B187: removed
Jul  8 14:30:01 nagios postfix/pickup[27607]: CCCF0B2B5: uid=0 from=<root>
Jul  8 14:30:01 nagios postfix/cleanup[23606]: CCCF0B2B5: message-id=<20140708173001.CCCF0B2B5@nagios######>
Jul  8 14:30:01 nagios postfix/qmgr[2259]: CCCF0B2B5: from=<root@########>, size=799, nrcpt=1 (queue active)
Jul  8 14:30:01 nagios postfix/local[23614]: CCCF0B2B5: to=<root@###########>, orig_to=<root>, relay=local, delay=0.08, delays=0.06/0.01/0/0.01, dsn=2.0.0, status=sent (delivered to mailbox)
Jul  8 14:30:01 nagios postfix/qmgr[2259]: CCCF0B2B5: removed
Jul  8 14:35:01 nagios postfix/pickup[27607]: A1EAAB3E1: uid=0 from=<root>
Jul  8 14:35:01 nagios postfix/cleanup[13484]: A1EAAB3E1: message-id=<20140708173501.A1EAAB3E1@##########>
Jul  8 14:35:01 nagios postfix/qmgr[2259]: A1EAAB3E1: from=<root@##########>, size=799, nrcpt=1 (queue active)
Jul  8 14:35:01 nagios postfix/local[13488]: A1EAAB3E1: to=<root@##########>, orig_to=<root>, relay=local, delay=0.07, delays=0.04/0.01/0/0.02, dsn=2.0.0, status=sent (delivered to mailbox)
Jul  8 14:35:01 nagios postfix/qmgr[2259]: A1EAAB3E1: removed
Re: Email notifications not working
Go to Admin -> Manage Email Settings -> Send A Test Email to test sending from XI. Post the maillog after the test and confirm whether or not you receive it.
vmesquita
Post by vmesquita »
    A test email was sent to <##################>
    Mailer said: SMTP Error: Data not accepted.
    SMTP server error: is syntactically correct
    (method=smtp;host=##########;port=25;security=none)
    An error occurred sending a test email!
abrist
Red Shirt
Post by abrist »
Could you pm one of us a screenshot of your XI email configuration?
Post by slansing »
Some of this may apply:
http://stackoverflow.com/questions/2227 ... iler-error
Are you absolutely sure you are using the correct port, and auth information? Do you have another system you can check this on? Such as your work station's mail client, etc?
vmesquita
Post by vmesquita »
Yes. I also tried sending an email directly from the command-line, using telnet on the SMTP server, and it worked.
abrist
Red Shirt
Post by abrist »
As you are not using any auth, try using the "sendmail" bullet instead of the smtp bullet.
vmesquita
Post by vmesquita »
With sendmail I get a positive response, but neither the test email or the notifications arrive:
Test Email Settings
    A test email was sent to ############
    Mailer said: Message sent! (method=sendmail)
Use this to test your mail settings.
An email will be sent to: ###############
Is this running 2014? If so can you post the contents of
tail -200 /usr/local/nagiosxi/tmp/phpmailer.log
