i just tried the Bulk modification for a CG on Host level and the corresponding CG was not assigned to all selected Hosts.
I tried then to remove the same from all services and now in Nagios XI (2014R1.2) under CCM -> hosts the corresponding CG got removed for the Hosts but if i check the .cfg filre for the host its still in there.
any idea what went wrong?
Matt
Bulk modifications for CG on host level is not working
Re: Bulk modifications for CG on host level is not working
Did you forget to apply configuration? Can you show us an example (screenshot and a config)?
