When I'm searching for a host with no services, I get no results in 2014 R1.2. This worked perfectly in Nagios XI 2012 R2.9. As I'm using installation and configuration scripts with quick actions, for example to install NSClient++ and generate nsclient.ini after adding the host, it was kind of useful that hosts appeared, even if they had no services.
Ok, I could bulk clone the services, then look for the host and then use the installation / configuration scripts, but this would generate errors, as the hosts doesn't have an agent yet. These errors would then be picked up by other team members or in case of critical hosts be sent to our on duty BlackBerry..
Thanks for looking into this.
Grtz
Willem
Searching for host without services no longer gives results
Re: Searching for host without services no longer gives resu
Another bug - confirmed. I filed an internal bug report (TASK ID 3513).
Ludmill,
This issue has been solved in R1.4. Thread can be closed.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
